I
i'm new to the programming world... about a 1 1/2 years, and have a question that i believed was the case for that time. i was under the impression that once you compiled and online configured a block into a module, that there was no way you could add a new block in a space that was between two already programmed in that module. so... ex. block 10,000 has a FC30, block 10,002 has a FC30, and you wanted to add another FC30 in space 10,001.(all within the same segment, redundant controllers, BRC400's) The only way to do so was to do a load to controller, not an online config. Is this true?
