inlet mass flow rate
B S Jhala
In Our GE Frame 9E gas turbine no instrumentation for inlet mass flow rate calculation is given. How i can i get mass flow rate of air by indirect means?
Also how to find out the mass of flue gases exiting from HRSG?
Use the search feature of control.com; this topic has been covered previously (at least the inlet flow portion of the question).
markvguy
I searched a lot but was able to find can you please help??
In Our GE Frame 9E gas turbine no instrumentation for inlet mass flow rate of air calculation is given. How i can i get mass flow rate of air by indirect means?
MOST units do not have a means of monitoring mass flow--inlet or exhaust. Additional instrumentation will have to be installed. This author has seen some extremely complicated methods for calculating exhaust mass flow-rate using inlet flow-rate and fuel flow-rate--but they were, at best, approximations and only used for trending purposes (increase or decrease), which can be quite useful for some purposes.
See http://www1.control.com/1026214347/index_html#1026214366
markvguy
