remove the bold on sides the flow divider below the pickup (see manual for pictorial view). Install magnetic pickup with nuts loosen. ensure a gap of 1mm between tooth and pickup with help of filler gauge. You can insert filler gauge with through the hole of the bolt that was removed from flow divider. tighten the nut of pickup and again ensure a gap of 1mm. Take help from your mech. section to get the GA drawng of the flow divider regarding the bold to be removed. Ensure that gap is not less than 1mm as it may damage pickup.
We want to order the magnetic pickup. In manual we found the type of the magnetic pickup : Airpax , Type 1-0216 with literature reference A07355. There are two drawing, 085-101-0216 and 085-101-0235.
But, at site, on the body of the magnetic pickup, we found :
82227/085-101-0245
185A1117P8 9E
PER DWG 085-101-0245
Please help us to choose what type of the magnetic pickup that can be install at flow divider for GE Gas Turbine Frame 9.
