i have a problem to make the necessary connection with fix software and modbus driver to transmit data through the serial port.
please can you give the necessary information and procedure to make fix software (fix software is an application software that is part of the Scada system to control and monitor and automate machines through some kind of protocol)?
i hope you can understand the problem and i hope you can respond as soon as possible.
