E Thread Starter eda81 May 2, 2013 #1 Tatsuno Lobe Flow Meter used analog (4 to 20mA) current loop for connection to PC. How to convert a 4 to 20mA to RS232? can be explained with the schematic? Thank you.
E eda81 May 7, 2013 #2 In the Tatsuno Lobe Flow Meter Datasheet only contains information that interfacing using 4-20mA current loop, not mentioned there whether 1.Is active or passive side? 2.Is 2 wire, 3 wire or 4 wire? 3.Is half duplex or full duplex? Does anyone know, Tatsuno Lobe Flow Meter Interface used 4-20mA current loop type what? Thank You.
