<Moderator's note: this subthread has been given a new topic and
title.>
> From: Peter Whalley <[email protected]>
> Subject: Re: ALL: An (open) announcement
> My understanding is that SOAP enables applications to
> intercommunicate via
> the Web using http and XML. Whilst it may replace DCOM in
> this application
> it would not neccessarily replace OPC.
This is obviously true. The main issue is likely to be performance, both at each end and in terms of network load. Most of the complexity of OPC is caused by it going to a lot of work to define a complex structure that can hold a lot of binary data to amortize network overhead. A similar XML structure will both be much larger and require substantially more CPU resources to construct and parse.
Despite the above, I expect the corporate world to
move to XML based data transport whenever possible. This makes the adoption of SOAP both reasonable and likely. However, I question how much payback there'll be from an OPC-like mass of data wrapped in SOAP/XML versus simpler structures.
Dan Pierson, <[email protected]>
title.>
> this application
