P
I am trying to use the parallel port to generate control lines to set up an external device. The external device requires 3 control lines that are TTL level terminatered int 93 ohms. Since I need to drive TTL levels into 93 ohms (parallel port needs to source/sink about 30ma), I was thinking of tying 2 data signals (D0 & D1, D 2 & D3,..) together to share the current load.
The 3 control lines are described below as well as a readback signal to verify the proper data was sent.
• GATE (write)= remains high for the 20 bits data stream.
• DATA (write)= 20 bit serial stream, 5 bits for address, 15 bits for data.
• CLOCK (write)= can be continuous or gated, with max freq = 16 kHz
• READY (read) = goes from a high state to a low state after the first 5 bits, then back to the high state after the 20th bit, planned on using a status bit for this.
Does any one know if I can do this and how?
If you can email me I can send the signal timing diagram in a WORD document.
Thank you,
Paul Taylor
610-354-2696
[email protected]
Thank you,
Paul Taylor
610-354-2696
[email protected]
