Check you have a window to open on startup: Special>Configure...>Window Viewer>Home Windows
If you are in Runtime, go to File>Open Window... and select the one you want.
Still, it shows nothing. +255758737654 WhatsApp pleaseCheck you have a window to open on startup: Special>Configure...>Window Viewer>Home Windows
Could not get youMake sure your Window Configuration has a good X, Y, Width, Height also.
Also try the Runtime button in the top right corner of the Window Make. i triedOpen the System Management Console > Log Viewer > Default Group > Local and see if you have error messages.
Also try the Runtime button in the top right corner of the Window Maker.
by Seth Price
by Seth Price
