E
Hi List,
I have an application that requires CO2 concentration of a gas mixture at high pressures (around 1000 psig). The IR CO2 sensor I'm using won't handle high differential pressures (line static pressure relative to atmospheric pressure). I've considered placing the sensor I have entirely within the gas stream, thereby
equalizing the pressure of the gas being analyzed
with the pressure imposed by the environment, but that's not that great of a solution either.
I don't really want to have to reduce the pressure
of the gas in order to analyze for CO2.
Do you know of any IR CO2 sensors that can
handle a high differential pressure (1000 psi flowing through the sensor and atmospheric pressure outside the sensor)?
Thanks in advance.
Eric Kelner
Southwest Research Institute GRI-MRF
San Antonio, Texas
210-522-3309
[email protected]
Thanks in advance.
Eric Kelner
San Antonio, Texas
210-522-3309
[email protected]
