We need to replace the VCMIH2CB card by the VCMIH2CC. what are the procedures to follow after inserting the VCMIH2CC instead of VCMIH2CB to reach the actual control state?
Why don't you start by telling us why you feel it is necessary to replace the VCMI card?
Next, what you have done to replace the VCMI? What are the steps you have performed, and where did you find the procedure for the steps you have performed? What were the results of the steps you have performed?
Have you checked the version of Toolbox you are using to see if it is compatible with the H2CC version of the VCMI?
Where did you obtain the H2CC version of the VCMI you have, and did you receive any software or instructions with it?
Which version of Toolbox are you using? (You can click on Help and then About from the Toolbox Menu bar to find the version number.)
Which version of the 'Mark VI System Guide', GEH-6421, are you using?
Do you know if the VCMI you are trying to download to has ever been downloaded to before?
Are you replacing one of three VCMIs in a TMR panel (a Mark VI panel with three control processors, <R>, <S> and <T>)? If so, what are the versions of the other VCMIs in the other processor racks in the panel?
Are you replacing a single VCMI in a SIMPLEX panel (a Mark VI panel with only a single control processor, <R>)?
