You can now access the LPC, but you should use the links on
http://claymore.engineer.gvsu.edu/lpcd
This will allow me to move the machine around the net without having to inform you about IP address changes.
I have made many improvements, and even a couple yesterday, and it seems very solid now. The java interface and LPC both have timeouts and other
fault tolerance communication features. The Java program should run nicely in netscape (I am not sure about explorer). If you plan to use telnet from windows you should consider setting it to give a local echo, and to automatically generate carriage returns - any unix telnet should be fine.
Hugh
LinuxPLC mailing list
[email protected]
Hugh
[email protected]
