With both processors loaded with the same program and dip switches set the same @ 10. I am unable to assign the same station address to the two processors in the RS Linx Lite driver Config. The list shows both processors. I give one a STA# 10 and assign the IP address, but when I try to set up th other it tells me I can't use the same STA# How can I set this up so that the BCMs work?
