I'm from the UK and am trying to understand what voltages are available in engineering laboratories in the UK. We have to ship over some laboratory equipment and are looking at potential problems.
In the UK our equipment runs from a 240v power AC supply (single phase - one live (hot) conductor, one neutral and one earth. Once in America this equipment will run in a chemistry / oil laboratory of several large companies. I believe there are two basic supply systems - 3 phase wye from which I could get 208v between 2 hot conductors or split phase from which I could get 240v between 2 hot conductors. Is it common to have both of these options available or is it likely that only one will be present?
The equipment is small and portable by 2 men although it contains a pair of servo drives and an associated control panel. Because it's lab equipment it will be built to 61010 rather than 60204. The equipment will be plugged in via a nema plug and suitable recetacle. If a Nema 6 is used then I have no access to the neutral line and the equipments control circuits must then run from 208/240v across the two hot conductors. Is this an acceptable option? If I use a Nema 14 plug I can use the neutral and hence run the control circuit at 120v. Any comments on the pros and cons or these options would be appreciated.
Many thanks.
Mark
Many thanks.
Mark
