O
Need to find out if one can control the level in the Vessel and the flow from the pump (downstream the GFUs/Vessel) independently.
These issues are:
4 vessels has a level control valves on the main suction side of header to the transfer pumps.
and there exist no surge tank transfer pumps discharge control to keep the pumps from running off their curves.
I am thinking of installing a flow control upstream the pump and a Flow Control Valve downstream the pump to control the flow and protect the pump from running off its curve, this will be independent of the Level control since we have many vessels feeding the pumps.
Just want to find out if this will work
These issues are:
