Y
I am having trouble setting up this system. Contents of a tank are to be monitored for an upper limit and a lower limit. In the event of an
inspection(tank completely empty), the flow counter is to be set to 0 to compensate for the flow sensors' inaccuracy. The relevant indicator flashes when the tank contents exceed the upper limit value(30) or drop below the lower limiting value(10). I hope someone will be able to give me a hand thanks for your time.
