K
Kirk S. Hegwood
>Given your parameters, I would fool around with using a SINGLE wire >hooked up to the input of a CMOS gate (inverter). You might have to bias >the input with a VERY high value resistor, but once you figure this out, >the wire hitting the liquid should be able to consistantly change the >output. You'll have to protect the input also, maybe with some zener >diodes. > >If you want to mess with analog, it would be better to use an op=amp or >a comparator, but I used a similar arrangement for a non-contact prox >sensor (another application where there was no room for the price of an >off-the-shelf sensor) and it worked fine. That way, you have six input >channels for about 15 cents. You may even be able to run the CMOS off >15V and run the PLC input directly. Now were talking. I'll have to look into this idea. >Don't you have to clean the goop off the wire in between jugs? Or is this >a static appplication, where the wires just sit in the jugs? Yes it is static. Once the jugs are placed into position, they are not moved until empty. We know how much is being dispensed with each application ~ 10-20ml. We can then set our limits to know how much is left BEFORE we run out. Trying to be proactive for a change.
