G
Can any one explain how to calculate the quantity of the liquid (The fluid is liquid Nitrogen)in a closed tank.
The tank volume is 44,080 litres.Rosemount Dp transmitter (model 3051) is used for measuring the tank DP. The range set for the DP transmitter is 0 to 7400mm H20, which corresponds to 0 to 100% of the tank level.
I am not sure about the tank height. Based on the above transmitter range(0 to 7400 mm H20) can any one tell me 0 to 100% corresponds to how many litres. I mean what is the tank capacity at 0% and 100%.
