I have a process which takes one of two products, either ground raw meat or slaughtering floor runoff water, into an open top square tank. Size is about 1m wide X 1.5m long and 1.75m high. This tank is the beginning of a recovery process for various constituents of the waste streams, and it is very dirty.
We're having trouble finding a stable sensing method for level in the tank. We have tried conductive probes, but the ground meat product deforms and breaks the probes. We have tried a simple pressure transmitter (diaphragm type with capillary tube sense line to isolate the mechanical vibration from the pump) but we keep finding the diaphragm damaged from junk in the waste stream. We have rejected a simple float mechanism because the ground meat would dry up around the mechanical parts and seize the switch. And we are currently trying to convince ourselves an ultrasonic level sensor can stay clean enough in spite of the splash from the liquid product.
One idea that has been proposed, but we haven't seriously
considered it yet, is to install a bubbler tube in the tank with a periodic water purge of the line to keep it clean.
Does anyone have a similar problem that has found a solution, or have an idea we're missing that might help. This is getting expensive.
Thanks,
Michael
Michael R. Batchelor - Industrial Informatics, Inc.
Contribute to society: http://www.distributed.net/ogr/
Thanks,
Michael
