List admin note...
K
Ken Crater
Hi all,
Welcome to the LinuxPLC list. The list was originally set up to allow only posts from subscribers, in an attempt to avoid spam. Unfortunately, the downside of this is that legitimate posts sometimes get stopped because the
address doesn't quite match for some reason. Of course, the very first post to the list, by Curt, got held :-(.
So, I've changed the list to accept posts from nonsubscribers. If a spam problem arises, we'll switch it back and manually enter the necessary
addresses for participants.
Let's build a great controller!
Ken Crater
[email protected]
LinuxPLC mailing list
[email protected]
Curt Wuollet
Ladder++ ? :^)
cww
root wrote:
> Some things that might be useful IMHO:
> The ladder program tagname, instruction comment and rung comment databases
> should be integrated into the PLC itself, rather than stored only on the PLC
> ladder programming application database (I've had to work on many machines that
> have had the orginal database file lost - what a major pain it is to try to
> reconstruct someone's old code from raw ladder and seriously out of date
> electrical drawings!). Long tagnames with strange characters should also be
> supported - like "clampSolenoid1.open( )" for instance.
> Many different types of data types should be supported in the ladder language
> (reals, shorts, longs, string, structures, arrays as well as the usual int and
> bool).
> The machine integrator should have the ability to create their own special
> purpose ladder instructions from their own C code with going through undo
> coding hardships.
> The ladder language should support many ladder program tasks, each of which
> should have its own local variables (by alias, not hard data file reference!),
> its own data type (maybe a structure named the same as the task name) to support
> identification of attributes and methods, and each task should be configurable
> as to its scan time and relative priority to other ladder tasks.
> For HMI/SCADA functions on non-speed critical machinery/processes, how about
> providing the machine integrator the option of using a stripped down web server
> running java servlets on the PLC. Web browsers are everywhere and can make a
> fair (and cheap!) HMI/data collection window into certain types of machines and
> processes.
> On another note, it might be wise to keep in mind that the open source PLC
> being developed here could also be used for the PLC side of a CNC. This would
> require fair amounts of memory to be shared synchronously with the CNC at
> relatively fast speeds (5 to 10 milliseconds for at least a portion of the
> ladder). It would also require fairly sophisticated floating point ladder
> instructions.
> A number of posts have mentioned that they are a little rusty on C coding to be
> able to support this project directly, but that they have been coding on the
> integrators side of things for some time. There could be a parallel effort to
> develop a large library of open source ladder example code which would be
> provided with the open source ladder programming IDE. How many times have we
> coded up ladder to control a cylinder of one type or another? A little thought
> to object definition and encapsulation would create some very useful code
> libraries. That would be a great feature for machine integrators.
> Alan Locke
> Controls engineer, Boeing
> "My opinions are my own and not necessarily that of my employer"
> [email protected]
[email protected]
