When generator on a shipboard plant is paralleled with other units this generator takes all the load and does not want to share load. Even when shedding load manually it will take it all back.
Then when a high consumer eg. air compressor plant starts up the generator cannot handle that load requirement and unit starts slowing down.
Plant engineers have replaced the governor (Woodward UG 8 dial type) with no affect on the problem. Can this problem be related to KVAR sharing or is this just governor set up problem?
