We have one machine with two motors driving same gear train through two different gear box. Master drive (40 HP, AB PF 700) is configured for speed control and slave drive (30HP, AB PF 700) is configured for torque control receiving 0-10VDC as Torque reference from master drive (torque command configured as 0-10VDC output). At the beginning machine starts normal but after few minutes of operation over load clutch of master drive slips (Ton-Torque). Is there any thing wrong in this configuration or there is any design issue. While in operation master drive draws 30 amps while slave drive draws 18amps.
Thank you,
Shree
Thank you,
Shree
