Dear All
I need to know the location of probe in Chimney. Is there any International Standard which tells where the sample probe for So2, NOx, O2 analyser is to be mounted?
Is there any thumb rule or standard which tells how to calculate the location of probe give the chimney diamer and height.
Also I need to know does the location of sample probe depend on the material of construction of chimney like Concrete or Steel. In other words, does it vary if the chimney is made of steel or concrete?
Who is supposed to tell about the location of sample probe? Is it the C&I design engineer or process design engineer or Structural / civil design engineer?
Also comes under which standard? mechanical or civil /structural or C&I standard?
anand s
anand s
