My customer wishes to log some data values from a PLC via MODBUS TCP. The data is only valid when the associated valve is open. Logging data every one (1) second. The valve is open between 5 and 30 seconds at intermittent times. The times between data logging can be several hours. Data logging is not an issue but viewing it is. The large times between data requires too much scrolling or searching. Try to locate a 10 second event in a days worth of data.
The customer needs a PC based, low cost solution to open and view the database. A trend display that can open the database and then change the viewing width (zoom out) to between 60 seconds and days. When he wants to examine an event he can move to that time and then zoom in for more detail.
We are not looking for an HMI solution since the factory floor is not where the data is required to be viewed.
Any good experiences or suggestions welcomed.
