When I trying to flash the firmware of the Floboss S600, it always shows the message like "Waiting for S600", after few seconds another message showed up "S600 has no response". I been tried like thousand times it turned out same thing everytime.
I tried the command line "ping", it respond normally.
The firewall setting has the exception for the software I use to perform the procedure. In the computer management, I checked the event viewer, nothing seems relevant.
But when somebody else try the same operation it just works. So, I'm confused, it seems to be some thing wrong with my computer's network settings, and I can't identify it.
This is the only problem I had when I'm trying to connect the S600. I can download the software to it normally, and I also can access to it's IE web page normally. Also my computer can browse the Internet perfectly.
After check plenty of documents and tried almost everyway on the Internet, it still stays the same way, also I been consulted to our IT group, nothing works.
So, if anyone can provide anything, you will be great help for me.
