E
We are looking for a liquid level sensor which should be deployed many times per printer. The ink container itself is 'small' ( inner dimensions : vertical dimension 27 mmm, width 30mm, depth 55mm), under pressure, and there is
not much space outside it.
A single point level sensor is OK. It should change its output when the level is below 10mm.
We can still apply small mechanical modifications (dimensions, material, ...) to our ink container
(ink is oil based).
Cost is a critial issue (max. 50 USD per sensor), as we need high quantities.
(ink is oil based).
