We need to install rotameters with the range as low as 1 - ml/min. Rotameter spec: Fluid: Nonyl Phenol Viscosity: 1 cp Spe. Gravity: 0.945 Temp: 35dec C Pressure: max 4 Kg/cm2 Measuring range: 1 - 10 ml /min MOC: ss316 If you are using such low flow rotamets, pls send us the details. Regards, P. Karuppasami Ph: 725623 Fax: 725630
