Major inspection maintenance was carried out on one of our Gas turbine. It is Frame VI (PG6581B) using MKVI controller system. But it was discovered later that the performance of the Gas turbine system in terms of Megawatt output after the MI is slightly lower than it's performance before the MI. Please I welcome very good suggestion about what might be likely cause of the drop in Megawatt, since the essence of MI is to have better output performance and more Megawatt.
