I have just put up an early release of the java programming interface for the LPC. It uses swing so you will need to have a new browser (ie Netscape 6), or install the java swing library from http://www.javasoft.com or use 'appletviewer
http://148.61.36.49/LPCedit.html'.
Mario has been working on a simple patch that will allow the LPC to use the SMM, so I have also included a simple build that cuts out all of the communications stuff, including the HMI and programming interface.
Hugh
Hugh
