If the gas turbine is running, it leaks lube oil into the generator. All effort to locate the exact leaking point proved futile. If the gas turbine is shutdown and the auxiliary lube oil is running ,you would not find any leakage of lube oil into the generator. The leakage is between the bearing number 4&5.
