We are facing an issue during the startup of one of our Gas Turbines Units. When the unit is on turning gear, Auxiliary lube oil pump (AC) is running and delivering normal pressure (around 6 Bars). However, during startup while unit is accelerating at 1500 RPM, the pump header pressure drops to around 4 bars and the bearing header pressure drops from 1.8 to 1.5 bars. Moreover, we observed that control oil pressure for IGV is also dropping from 3.8 to 1.9 bars.
All the above parameters reached to the minimum at around 1800 RPM, after that it starts to accelerate again gradually until it reach to the normal values near to FSNL speed. After loading the units, the parameters also are OK.
Remark : No recent activities were done on the units.
Please advise your thoughts and possibilities if someone faced similar experience before.
