K
We have a customer with an underground storage tank. Installed in the tank is a magnetostrictive float based level sensor that measures the level of the brine solution between the inner and outer tank walls, thus providing leak indication if solution level should fall or if it should rise below a fixed point.
The problem is every time there is a lightning storm, we end up getting a false alarm on the panel. We've verified all system grounds and the cable between the sensor and building for proper shielding and that it is in a isolated conduit. Any body know what's up, would appreciate all feedback
TIA,
Kris
TIA,
Kris
