H
When the unit is on turning gear and 88QA running, it delivers 5.5 bars, but when the unit runs to full speed no load and the main pump running, it is observed that the pressure drops to 2.7 bars.
We have shut down the unit to investigate. The I/C team have checked 96QA-2 and it gave the desired reading. I opened the compartment where the VPR-2 -1 is and found that there is a test point for I/C but I was a little confused that it wasn't closed. At that point, I was not sure if it is supposed to be so.
Suggestion is now being made for us to regulate the VPR-2-1 when we run up the unit.
Again, I must say at this point that we also checked for leakages along the line but there was none.
Please, I implore this honourable house filled will vast array of knowledge to share if any have had this problem and how did they go about solving it.
Thanks in anticipation of your usual support.
