hello,hello,
what are the operations of major and minor inspection related to instrumentation other then the calibration of instruments
thank you in advance
hello,
There are many useful informations regarding Minor/Major Inspection on the web, but you can first read this thread for better idea on this subject:
https://control.com/forums/threads/ge-gas-turbine-major-inspection-mi-scope.46384/
Controls Guy25.
okk thank you so much for your adviceHi Lifa, my answer today would be same as it was when I wrote the above reference. It's called Predictive Maintenance (used to be Preventative Maintenance) in a few words, fixing things before they break down. Firstly look at your plant and see what has been causing you problems, do you perform regular load tests, they will help you to evaluate, look at costs vs. improvements. Be careful doing 100% instrument checks, sometimes this can cause more problems than leaving them alone, for sure 100% on Protection then highly troublesome stuff particular to your plant, then, particularly if downtime is very expensive to your plant, things like replacing servo valves.
The main thing is know your plant and what is causing you problems.
M | Major Overhaul for a Frame 5 GE Gas Turbine | Power Generation | 0 | |
G | GE Gas Turbine Major Inspection (MI) Scope | Power Generation | 3 | |
G | 1734-IE8C Major Channel Fault | Process Control | 2 | |
B | All the Major Fieldbus Protocols in One Course? | General Communications Chat | 2 | |
O | Low CPD of GE Frame 9E After Major Inspection | Power Generation | 0 |
by Seth Price
by Seth Price
