We are trying to post values on certain registers at a certain rate (~33 Hz). We use a TON block (T32) and set the PT to 34 ms. Using the compare integer block (I>=33), we trigger the subroutine that manipulates the input data and posts the value on output registers.
Is this the right way to get data post at 33Hz? How can I use an oscilloscope to measure data is posted at 33Hz?
Any other ideas suggestions will be greatly appreciated.
