Ive got a momentum M1E 980 20 connected to an industrial ethernet and have added an ethernet IO module to the ethernet to increse the IO capacity of the PLC and also provide a remeote IO point, however i cant seem to find how you map this IO into the momentum with proworx.
I have comms working between the plc and Io module as i have setup an IO scanner (in config extensions) that reads registers 400001 and
400002 from the IO module, as each bit of these registers corresponds to a input or output on the IO module.
Can i map the IO into the momentum so i can program them as just inputs/outputs, i.e. 1xxxxx/0xxxxx or wil i have to write some logic to
look at each bit of the two status registers and set coils correpondig to the state of the bits
