K
We at Kuala Langat Power Plant, Malaysia, are facing some problem with ac interferences in the 125 Vdc digital signal of MK-V system. Some terminals that we measured with a multimeter could reach up till 8.5 Vac. Can this high ac voltage cause any damage to the other boards over a long period of time?
Also, may i know what are the specs of the diodes that can be used to filter out the AC interference? As i have found that the dc siganl only carries about 4mA, is this correct?
Thank you.
Thank you.
