R
Following Diagnostic alarm has happened at the time of rolling of our steam turbine, which was stopped and started (rolled, synchronised). On rolling after two hours (with out any job on machine or control system) following diagnostic alarms related to <S> processor have come. These are related to overspeed, but the loopback alarm of ETD is not clear and may be a threat (?)...
There is a button for 'Master reset' which in Steam turbine we have never used, but in gas turbine we are using this reset feature many times with out any problem. In the rungs this master reset button in Steam turbine MarkV is resetting many cards including TCEA. We are not sure if this Master reset button can be used to clear these alarms, and also not sure if by doing so will it initiate a Trip? can anybody guide us...
Diagnostic alarms:<pre>
S1 1 C 2374 Voter mismatch, <S> L4ETR1_FB
S1 1 C 2375 Voter mismatch, <S> L4ETR2_FB
S1 1 C 2378 Voter mismatch, <S> L12H_ACC
S1 1 R 1696 TCE1 TMR check trouble, ETR1
S1 1 R 1697 TCE1 TMR check trouble, ETR2
S1 1 S 1696 TCE1 TMR check trouble, ETR1
S1 1 S 1697 TCE1 TMR check trouble, ETR2
S1 1 S 1713 TCE1 Loopback, solenoid, ETD1/SOL1/MTSV
S1 1 S 1714 TCE1 Loopback, solenoid, ETD2/SOL2/ETSV
S1 1 T 1696 TCE1 TMR check trouble, ETR1
S1 1 T 1697 TCE1 TMR check trouble, ETR2</pre>
If not what could be the problem..?
