G
Following are the instantaneous value inputs to the GAS_FLOW_CALC1 Block for the GE Frame 5 gas turbine.
Note: following are snapshot values.
FDG1 : 574 mmWc
FDG2 : 575mmWc
FPG3 : 17.30 Kg/Cm2
FQG : 1.17 Kg/S
FQKGDB : 76
FQKGG : 1.046
FQKGSG : 0.608
FQKGSL : 737
FTG : 53 Deg C
Orifice details available from performance guarantee test calculation sheet given at the commissioning time are as follows:
Diameter of Pipe @ 20 Deg C : D' = 0.154051 m
Diameter of Pipe during test : D = 0.154109842 m
Flowing Temp : FT = 54.95 Deg C
Beta : 0.582160533
Problem: the FQG calculated by Mark V is 1.17 Kg/s. using a Daniel's flow calculator for these values the gas flow reading is 1.46 Kg/s. (I'm not sure if the Daniel's flow calculator that I have is a licensed version.)
Given these facts, is there a reason to believe that Mark V's FQG may be wrong and needs some change of constants?
Thanks.
FDG1 : 574 mmWc
FDG2 : 575mmWc
FPG3 : 17.30 Kg/Cm2
FQG : 1.17 Kg/S
FQKGDB : 76
FQKGG : 1.046
FQKGSG : 0.608
FQKGSL : 737
FTG : 53 Deg C
Beta : 0.582160533
Thanks.
