dustinHi ,
Thanks for you replay ,
My goal is not to clone hdd an run it on an old pc to communicate with mark V .
my boss will give me an hdd taken from a machine ( Old machine ) that is running acutually and communication with mark v.
turbine.
i have a P4 machine : Win 98 to clone the hdd
i have an old machine amDX4 with 1 Mb memory: to test if the cloned hdd will work .
i dont need to test de com with arcnet .
If the cloned hdd works on the dx4 machine , i will send it to our foreign engineer so he cant starts developping new hmi ...
what you say here , is good for me :
**** Anyway, I think you could probably take the <I> (IDOS) hard drive, put it in a machine with IDE capability as a non-primary disk, and then use Acronis or something similar to duplicate the drive to another disk; that would probably work.***
Thanks .
Dustin,Hi all ,
Thanks for your help.
i was able to clone a working idos hdd . the cloned hdd boots successfuly on an old machine and i can see the old hmi and access to program.
Cause i am curious , i added the arcnet card in isa slot , i know the irq of the arcnet is 15 but no communication with the controller.
any iidea ?
Thanks a lot.
I | How to Edit Unit Name in MARK V IDOS | Power Generation | 1 | |
R | Switcing from IDOS on Mark V to DOS Prompt | Power Generation | 2 | |
L | mark V IDOS | Power Generation | 3 | |
A | MARK-V (IDOS) Historian Installation | Power Generation | 2 | |
V | MARK V IDOS not able to edit rungs and prom files | Power Generation | 24 |
