Simulate freq to pulse rate input_1 from PTBA card input. Found on HMI pulse rate input_3 also indicate value. Suspected interference from other source
Way too many mis-spellings and problems with the information provided.
The PTBA card is the I/O terminal board for the <P> core, which contains the TCEA cards (three of them), the TCEB card, and the TCTx card.
The TCQE is a pretty special analog I/O card which is used with proximity-style vibration sensors, primarily, but can accommodate some other analog I/O as well (refer to the Mark V Application Manual, GEH-6195, Appendix D, for more information about the I/O capabilities of this card).
The TCQE is usually connected to the TBQE I/O terminal board.
So, the information provided is just completely unintelligible.
Perhaps if you told us specifically what you were trying to do we could help or understand better. We get that you're trying to use a frequency generator (zero-crossing, I hope!) to simulate speed input. But for what specific input signal(s)?
