H
We are facing a problem when making change-over from Gas to Oil. First we start with fuel gas smooth operation till we reach full speed and GT was loaded to about 5 MWatts. Then we select from DCS fuel change over to Oil (our Bailey DCS connected by serial link to MarkV system). At this time we start priming for fuel oil lines. After about 6 seconds the turbine trip and next 3 alarms came at the same time:
Q 72 TRUE PALARM PROTECTIVE MODULE OVERSPEED TRIP
Q 73 TRUE PALARM PROTECTIVE SPEED SIGNAL TROUBLE
Q 512 TRUE PALARM EXTERNAL TRIP TO (P) 4 RELAY CIRCUIT
We checked all operating conditions before the trip from the trip log display and it was OK, even the speed did not increase to overspeed and it was normal.
Our system is Simplex, Mark-V Frame V GE GT, we have 3 TCEA cards so we do not expect the problem in it as turbine is working good with fuel gas, only this problem during fuel changeover from gas to oil. We do not know what is the relation.
We replaced the trip relay (TCTG) but the problem is not solved.
Can anyone help us to solve this problem?
