During weekly Mix fuel operation of Gas turbine Frame 9E following Diagnostic alarms appeared on screen and they are not getting reset.<pre>
><R>0058 TRUE DALARM DCC I/O CARD OBJ ID #14 RESET
><s>1696 TRUE DALARM TCE1 TMR CHECK TROUBLE ,ETR1
><s>1697 TRUE DALARM TCE1 TMR CHECK TROUBLE ,ETR2
C>1824 TRUE DALARM VOTER MISMATCH, <r> 28FDA
C>1825 TRUE DALARM VOTER MISMATCH, <r> l28FDA
C>1826 TRUE DALARM VOTER MISMATCH, <r> l28FDA
C>1827 TRUE DALARM VOTER MISMATCH, <r> l28FDA
C>1832 TRUE DALARM VOTER MISMATCH, <r> L5E_TCEA
C>1833 TRUE DALARM VOTER MISMATCH, <r> L4_FB
C>1834 TRUE DALARM VOTER MISMATCH, <r> L52B_SEL
C>1835 TRUE DALARM VOTER MISMATCH, <r> l12H_P
C>1836 TRUE DALARM VOTER MISMATCH, <r> l12L_P
C>1838 TRUE DALARM VOTER MISMATCH, <r> l14L_ZE
C>1840 TRUE DALARM VOTER MISMATCH, <r> l30AS1
C>1841 TRUE DALARM VOTER MISMATCH, <r> l30AS2
C>1842 TRUE DALARM VOTER MISMATCH, <r> l30AS3
C>1846 TRUE DALARM VOTER MISMATCH, <r> l4ETR1
C>1847 TRUE DALARM VOTER MISMATCH, <r> l4ETR2
C>1848 TRUE DALARM VOTER MISMATCH, <r> l4PTR1_FB
C>1849 TRUE DALARM VOTER MISMATCH, <r> l4pTR2_FB
C>3534 TRUE DALARM VOTER MISMATCH, <r> TNH_OS</pre>
Kindly suggest which card like PTBA TCT, TCEA I SHOULD CHECK OR JL CABLE 1, 2, 3, 4, 5, 6 NEED TO BE CHECK
