Troubleshooting a GE Mark VI- TMR system.
The Diagnostic alarm is present on SLOT 8 VCRC. I have attached a screenshot of the alarms present. Searched the site and seems the issue was talked about .
https://control.com/forums/threads/vcrc-diagnostic-trouble.45709/
I've confirmed 110 Vdc (¬ 106.9Vdc) voltage supply to the TBCI terminal board from the PDM. I've checked the connection they are all tight no loose connections.
Is it possible there a configuration on the VCRC card that I'm missing?? . I've downloaded config and firmware, checked for the difference in configuration from the toolbox and everything seems ok.
Any other options I can try out???
