Mark VIe Virtual Controller
H
houssamicss
While Starting the application in Mark VIe Virtual Controller, I've got those alarms:
EGD: subnet mismatch between application and simulator configuration.
EGD: Unknown or inaudible var AUXSTART_C_CDH requested in contract
APP: egd-consumer.xml : Egd contract Error -3
APP: EgdXml Serialize Failed
Thank you for help
From the error it is clear that your Ip address configuration is not matching with the Simulator Configuration. Make sure your subnet mask is configured Properly. Usually mark Vie use 2 kind of Subnet. One with Network Class B Device address will be like 172.16.101.111 & Subnet mask will be like 255.255.240.0.
Other one is Network Class C 192.168.101.111 & Subnet mask will be like
255.255.255.0.
Verify your Loop back adapter settings and the Virtual Controller settings are the same.
