After replacing the srv servo valve, we checked the LVDT voltages and found as 0.74 V at 0%. Actual valve position is also -0.1 % in HMI.
In machine operation, srv passes even when it is in negative position (-2.1%) shown by the HMI value.
I tried to put -10% value and got LVDT voltage as 0.70 V. Then this value is put in IO configurator as 0%. On operation valve position is 0.1% and valves passes also.
How can I close the valve fully?
Should I reduce the LVDT position and voltage according to valve position?
Is the actual valve seat passing?
Can anyone give me a proper procedure of calibration in this case?
Thanks and Regards
Thanks and Regards
