Hi Everyone
throught my learning about Master/Slave configurations
ex1:
I have a master 314 C-2 DP CPU and Profibus DP master system(dashed line),then drag and drop IM 152-1 set it as slave then add it's i/O modules,in this case the master CPU have direct access to the slave inputs/outputs
ex2:
I have a master 314 C-2 DP CPU and Profibus DP master system(dashed line),another 314 C-2 DP is set as a slave cpu,
the maste cpu doesn't have direct acces to the slave I/O so a memory area is defined as shown in pic 1
(address=4/length=2/unit=bytes),does't mean that the memory area have start address=4 and a length =2 bytes so it's (4.5),so if i have 16 sensors the length would be 2 if i have 24 sensors the length would be 3 in case of digital sensors,and what does consistency means,depending on what we set those parametres
ex3:
I have a master 314 C-2 DP CPU and Profibus DP master system(dashed line),and 313c connected with CP 342-5 to serve as slave,pic2
what's the meaning of 2bytesDI/consistency unit ,is't 16 bits of input memory (the memory which the master CPU read from),if he (313c connected with CP 342-5 ) station have SM modules how will the master reads from them
am confused with the presence of CP module
pease correct me if am wrong
kind regardes
ex1:
ex2:
ex3:
kind regardes
