H
We have got butterfly pressure control valves inslalled in natural gas metering skid, high pressure (74 bars).
The purpose of this query is to remove kicks on these valves and to ensure a smooth continuous control.
The investigation shows that kicks are noticed when the control is in auto mode with an important differential pressure (> 4 bars) through the valve. This happen, when the outlet pressure is low ( about 62 bars) and valve opening is low ( about 25%).
In such situation, with a high differential pressure (4 bars), the valve position does not respond to 1% output variation.
Do you recommand any solution ? other valve type ?
Hafedh Ghodhbani
Hafedh Ghodhbani
