E
Momentary pushbutton inputs to control PC digital IO. Pushbutton A is used now to control machine to start machine when hit once, and then continue next operation when hit again. But if Pushbutton A is double hit, then the machine just starts and goes right into the next operation and the operator did not think they hit it two times. Which is a super safety hazard!
What I want to do is to have two buttons to control this operation without a PLC. Pushbutton A will start the process, and with an added pushbutton b will continue the process. But the catch is once pushed, button A is triggered to start then it is out of the equation until pushbutton b is triggered to continue the operation. Can you help me?
This machine has an old motion PC program with digital PC IO connected to servo drives, and mostly everything is in German. So it makes it hard to change anything on this machine. Is it possible to connect two NO momentary pushbuttons to one input so I can trick the machine without have to mess with anything else?
