Need help configuring ethernet card (aj71) for communication with MIE driver of intellution. If anyone has a sample program it would be much appreciated.
please explain your problem, the connection should be straight forward if it is the right Intellution driver NETDDE should be running and working start hooking two PC and test netdde operation You need a program? does it mean that you need an interfase program? then your Intellution driver is not the right one? Regards German ********************************************************************** German Lopez, [email protected] Production Testing Services, Technical Support Eng. TRV 19A 121-11 Ph 57 1 637 2577 FAX 57 1 6373990 Bogota Colombia, South America In Houston: Production Testing Services Inc. 6226 HWY 6th South, HOU TX 77083 PH 281-493-2500, Fax 281 493 3338
