In our existing system we have open delta connected Busbar PT which gives sensing to MK VIe for busbar voltage inputs.
Now we are planning to replace open delta type PT (which has grounded reference secondary) with star type PT. So we need to install a new 1:1 interposing PT to get ground reference for voltage input to MK Vie sychronization ckt.
The secondary phase to phase voltage for both type of PTs is 120Volts.
The Synch resistors are rated at 500 Ohms (Wattage is 225W as per BH data sheet)
What should be the burden of this interposing PT ? and what is requirement of this synch resistor
Attached : existing synch ckt drawing
